I just installed a Mark VIII fan on my 86' but the fuse keeps blowing when the fan comes on.
So here is the setup:
Mark VIII electric fan
Spal PWM Controller w/ Spal Thermostat
I wired everything as per spal's instructions. The only notable difference is that the Lincoln Fan has two + wires (brown/orange stripe and blue) so I just chose one (brn/org) for the + and taped the other off. I used a 30amp fuse on the battery side of the spal controller. I've rechecked my wiring and don't see any obvious problems. I saw an article on www.fordmuscle.com where they did the exact same install and used a 30amp fuse and according to them it worked fine. So where did I go wrong? Anybody with any experience with this install or ideas as to why the fuse is blowing? How many amps does the lincoln fan draw and how many can it handle?
Tomorrow I was going to swap the + from the brn/org to the blue although I don't think that will help? If that doesn't work I was also considering adding a relay to the + at the fan side so I could protect the controller (I believe it can only handle 30amps) and add a fuse so I can step up the fuse size. Sorry, I'm not sure if that last part makes sense.
