Intake Manifolds for 302
N242
90
hi
i have 302 engine and i think over about Intake Manifolds.
my carburetor is holley 4150 600 CFM DP .
i think about
summit Stage 2 \ X-CELerator \ Stealth
so what are you recommender ?
The Weiand Stealth and the Summit Stage 2 are the exact same manifold. Weiand must make the Stage 2 for Summit so they can use it under their brand name, they are totally identical in every way.
The real question than is between the Stealth and the X-Celerator. The Stealth is a dual plane intake good till about 6500rpm, and the X-Celerator is a single plane intake with a different powerband that starts later but goes until 7000+rpm.
If you plan on driving on the street mostly and only occasionally racing at the drag strip, either the Weiand Stealth or the Edelbrock RPM Air-Gap will be your best choice because of their street friendly rpm range and outstanding low end torque.
If you plan on racing more than street driving, forget the X-Celerator and look at the Edelbrock Victor Jr. single plane intake. The Victor Jr. makes a lot more top end power than the X-Celerator, but neither the X-Celerator or Victor Jr. is optimum for street driving because of their higher rpm range and loss of low end torque.
Wieand Stealth...
FWIW:
The Summit intake IS NOT A WIEAND!
It is a cheap Chinese copy with very poor quality!
On our Maverick board a guy bought one and posted pics of the poor quality.
I'll see if I can scare them up.
The machine work itself was scary bad.
Wieand Stealth...
FWIW:
If that is the case than by all means, please post some pics. Chinese made Weiand knockoffs? Damn, I only thought the Edelbrock intakes had been ripped off.
