ANOTHER FUEL PRESSURE QUESTION
WHEN YOU HAVE MORE PRESSURE, YOU HAVE MORE FUEL. yOUR ALSO LIMITED TO WHAT THE INJECTORS SPEW OUT AND HOW MUCH FROM WHAT THE COMPUTER TELLS IT. can you hear me now? lol
WRONG.
The higher the fuel pressure, the less the volume.
A 190lph fuel pump is equivalent to 50gal/hr. Here is an example pump flow rate for a 190lph fuel pump with flow in gal/hr. As you can see, the pressure to volume is an inverse relationship.
Fuel Pressure (psi) gal/hr
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
WRONG.
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
What subject are you talkin about? Where talking fuel pressure and fuel injectors and your talkin pumps. Do u set ur fuel pressure lower at your fpr and the gauge mounted on your rail expecting more fuel pressure at your injectors? For u engines sake, i hope not
WRONG.
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
I'm not really sure what you are getting at here, but I don't think this is the question the original poster was trying to ask...
When you increase the fuel pressure in the rail, then more fuel is going to flow for the same injector pulsewidth.
In other words...
More PSI = More Volume Flow
Again, I'm not sure what your getting at with the pump comments...
Maybe you can elaborate?
jason
In other words...
jason
thats what i was getting at, but I guess the obvious isnt so obvious anymore. Apparently more fuel pressure on the line = less fuel flow through the injectors. I hope this guys engine doesnt lean out.
ok so how much pressure would 19lb inj stand? and what is the stock regulators pressure?
Here is the answer to the question you were trying to ask...
Your pressure should be set pretty close to the factory level; 38-41psi, depending on what book you look up the spec. in.
The answer to the question you did ask...
The stock system *should* be able to handle up to 50psi (or up to 60psi if you believe some sources), with out any metering issues from the injectors.
By the way... If the fuel pressure has to be set this high (over ~45psi), then there is a deficiency in the system somewhere.
For the most part stock pressure is the "BEST" pressure setting. Moving away from the stock pressure can cause ecu issues.
My rambling thoughts,
jason
