stangman16 Active Member Nov 16, 2004 640 4 29 San Antonio, TX Jul 7, 2007 #1 Jul 7, 2007 #1 Would #19lb 4.6 fuel injectors work with a 5.0 ? They look almost the same...
montegoman351 Member Jan 12, 2007 169 1 18 Jul 7, 2007 #2 Jul 7, 2007 #2 Yep, they'll work, since their newer, they more than likely have the 4 hole pintle, which is better for atomization-thus more power.
stangman16 Active Member Nov 16, 2004 640 4 29 San Antonio, TX Jul 7, 2007 #3 Jul 7, 2007 #3 awesome, I noticed the 4 hole pintles also when I compared the two... but two of the eight have broken caps by the pintles. Would they still be okay to use?
Gearbanger 101 Straight Outta Locash 20+ Year Stangneter Aug 10, 2002 9,457 1,377 234 Ontario, Canada Jul 8, 2007 #4 Jul 8, 2007 #4 They'll work as long as they've got the old style connector. The later 4.6's use the newer style connector to mate to the injector harness.
juiced_94gt Active Member Mar 30, 2005 1,143 0 36 Southern California Jul 8, 2007 #5 Jul 8, 2007 #5 search ebay, they have a rebuild kit (pintels-o-rings-filter) for 20.00 and it's super easy to do at home.
stangman16 Active Member Nov 16, 2004 640 4 29 San Antonio, TX Jul 8, 2007 #6 Jul 8, 2007 #6 The 4.6 one's I had from my friends '96 GT work just fine - my EFI project finally is running! Thanks to all and especially to jrichker
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,179 17,884 224 Massachusetts Jul 8, 2007 #7 Jul 8, 2007 #7 Gearbanger 101 said: They'll work as long as they've got the old style connector. The later 4.6's use the newer style connector to mate to the injector harness. Click to expand... Onlt on the Cobras and i beleive the S197's. The PI GT's get the same style connector. They are 19# up until 2002. Around 2003, Ford switched to pink injectors which are 22.5 # injectors. You would need a tune to be able to use those however. A 24# mass air MIGHT be able to run them if the 02's can compensate enough but not sure
