4.6 fuel injectors?
They'll work as long as they've got the old style connector. The later 4.6's use the newer style connector to mate to the injector harness.
Onlt on the Cobras and i beleive the S197's. The PI GT's get the same style connector.
They are 19# up until 2002. Around 2003, Ford switched to pink injectors which are 22.5 # injectors.
You would need a tune to be able to use those however. A 24# mass air MIGHT be able to run them if the 02's can compensate enough but not sure
