Help, Wont start
nseand
9
I just picked up an 87 with the maf conversion and a ton of work done on it but it wont start. Gets spark, has press gague on the fuel rail and reading close to 40 lbs. I am getting voltage ath the injectors, and spark. I have replaced the plugs, the module on the dist, cap, rotor, coil, plugs ( plugs were wet when I took them out) . Even tried spraying starter fluid in the throttle body and nothing. Turns over, has compression just wont fire. I am going to replace the pickup on the dist this week and cross my fingers. The car was rarely started in several years as it sat in someones garage, they said last time it ran for 5 sec and never wood start again. The fuseable link (20 ga) was corroded so I replaced that. Fuel pump comes on and primes as well. I was thinking bad gas, but put in a bottle or 2 of gas conditioner incase there was water back there, but I am at a loss here. The last thing I want to do is have it toed somewhere and pay an arm and a leg. ANy thoughts?
been there tried that. Since it was running before and the dist was never moved, I have a hard time believing it to be the dist. I pulled the cap to make sure the rotor turned to be sure the timing chain didnt break, and the rotor turns just fine. It gets spark, gets fuel ( not sure if the fuel is bad( but even bad fuel should ignite. It wont even crank on starter fluid when I spray it, but it gets spark like a champ. Plugs are wet, can smell gas, computer gets power, injectors get power, all power at the fuseable links, fuel pressure says it is close to 40lbs after the regulator, fuel pump primes , any other thoughts?
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 29-Jun-2007 to update TPS testing procedure for 94-95 Mustangs
All text applies to all models unless stated otherwise.
Note: 94-95 specific changes are in red
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
Most of the items are electrical in nature, so a test light, or even better, a voltmeter, is helpful to be sure they have power to them.
No spark, possible failed items in order of their probability:
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
94-95 models only: EEC or PCM power relay in the constant control relay module. Look for 12 volts at the fuel injector red wires.
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
94-95 models only: 20 amp EEC fuse in the engine compartment fuse box. Look for 12 volts at the fuel injector red wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp fuse
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
A.) Moisture inside distributor – remove cap, dry off & spray with WD40
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
E.) Coil weak or intermittent - you should see 3/8" fat blue spark with a good coil
3.) Spark at spark plug, but no start.
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct.
Two reasons:
1.) If it backfires, the chance for a serious fire is increased.
2.) On Mass Air cars, the computer needs to measure the MAF flow once the engine starts.
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
4.) No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter. Look for 12 volts at the Pink/Black wire on the fuel pump relay.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-90 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay.
91-93 models only Blown fuse link in wiring harness. Look for 12 volts at the Pink/Black wire on the fuel pump relay.
The fuse links for all model years 86-93 live in the wiring harness near the starter solenoid.
94-95 models only: 20 amp fuel pump fuse in the engine compartment fuse box. Look for 12 volts at the Dark green/yellow wire on the constant control relay module.
F.) Engine seem to load up on fuel and may have black smoke at the tailpipe. Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed. Check the regulator vacuum line for fuel too. Disconnect it from the engine and blow air though it. If you find gas, the regulator has failed.
5.) Fuel pressure OK, the injectors are not firing.
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
On a 94-95 Mustang, probe the black/white and grey/white wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
B.) Failed computer (not very likely)
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order from the non HO engines.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
been on the checklist and following it, doesnt seem to help ///////////I get spark and I get fuel................could it be a bad mass air? or pip in the dist? I have replaced everything in the dist BUt the pip, figure for $20 I might as well do it too. Does anyone know if they can test the computer if I take it somewhere?
Just keep going down the list and you should find the cause.
FWIW, if you have spark and injector pulsing, your PIP should be fine. While replacing parts is great, you really dont want to introduce more variables. Get the car running and then if you want, replace items one at a time (so if there is an issue afterwards, you dont have to wonder which of 20 parts caused the issue).
Good luck.
since there is spark and it is getting fuel, would you drain the tank or start looking at sensors and or computer?
Where are you at on the checklist?
This helps everyone stay on the same page. For instance, I have no idea what having fuel means. To me it means the fuel rail is seeing 30+ PSIG of fuel pressure, but it could also mean you have injector pulsing I suppose.
Because you have voltage to injectors and spark, your computer should be fine. Again, keep running the list because it will save recursive chasing of one's tail or testing systems you have deduced to be ok. And don't skip steps. If you need something like a noid light, it's worth it to hit the store, spend 5 bucks and get one. It can save lots of time with erroneous troubleshooting; there's logic in the order in which JRichker constructed his list.
We just wanna see you get it fixed and back on the road as soon as possible and for the least cash outlay.
Good luck.
well if I am getting spark AND fuel then #6 would apply, unless I am reading this wrong????Unless the spark wasnt strong enough to ingite the gas? I am probably going to drain the tank , change the gas filter, and then start from square one. But since it has spark and has gas, it has to be a sensor or somehting. I know you said go in order but I have. I get power to the injectors, plugs are wet, AND it has spark. which eliminates almost the whole list, right? Just for ****s and giggles i am going to drop in a new distributor.
The last time I had your problem, it turned out to be a weak coil. I had enough voltage to jump a gap while testing. I did not have enought voltage to jump a gap with normal engine compression.
My thoughts exactly, I replaced the coil and the distributor today, still have orangish bluish spark. I am seriously considering dumping all the gas and going from there. I am getting messed up readings from the tps. I took a file and elongated the holes to make it adjustable and got the key on voltage on the green wire to 1.02 but it is over 4 on the wot.... Still looking at the maf sensor and debating. I am the type that will replace it all before I take it elsewhere. SO I am on new coil, replaced fuseable link that looked worn, new dist, new module, new pluge, wires are fine, 12.93v at the injectors, power to the eec, fuel pump primes and comes on, 36lb press on the rail...............I am getting in the pissed stage..................... been thru a case of beer as well.
Also if you haven't, give it some time. Your plugs might be fouled (in my experience, shutting the injectors off if they're fouled badly doesnt do much. Gotta let 'em sit or remove and clean 'em).
Good luck.
