You dont have to grind anything...just remove your altenator (2 bolts) and they drop right in, the oil fill is a minor mod compared to the grinding most people do to get the foc covers to work, i was worried today but everything fit like a glove
I have them on my car, well the drivers side anyway for now. I took off the pass. side to cut the oil fill tube as I am going to run a short rad. hose or like hose to the cap and clamp it to the remaining stock oil fill tube and bottom of the cap.
I am debating on getting the covers powdercoated to match the intake/brackets this winter.
I had the same problem with the pcv hose on the oil fill tube that Grady is having. I put a hole in the radiator cam and installed a fitting there and attached the hose there. I'm gonna redo it with the cam swap I post pics of it as I go along.
I guess I could have said I cut the filler neck in half and repositioned the top
half as needed with a radiator hose from a little ricer car of some kind
