Which one produces more drone an o/r x -pipe, or an o/r H-pipe? which one is better for performance? Thanks.
-Alex
-Alex
Hmm i guess i should lean more towards the o/r H-pipe because i have series 40 flowmasters on right now. But i also heard the the o/r hpipe with flowmaster mufflers makes like a farting noise when you release the throttle, dunno if its true or not or if it makes that big of a difference
H pipes will have the popping noise when releasing the throttle.Hmm i guess i should lean more towards the o/r H-pipe because i have series 40 flowmasters on right now. But i also heard the the o/r hpipe with flowmaster mufflers makes like a farting noise when you release the throttle, dunno if its true or not or if it makes that big of a difference
Alright i heard and compared the differences between the H and the X, and i think im going to go with the H. But is it even worth buying a whole new pipes as apposed to just cutting out the cats from the stock H-pipe and replacing them with tubing? A stock Gt comes with an H-pipe right? and what are the diameters? because all the o/r H-pipes i see online are 2.5 inches. Thanks
-Alex
I definitely recommend a pro-chamber h
-Alex
You'd love the prochamber with the flows![]()
It's worth just buying one. You wont see as much of a gain as you would with a pre made one. Weighing the price and the time to modify the existing h-pipe plus with the small tubing....it's worth just buying one. You can find used ones for cheap too.
