A chance to get gears...
Tally_4.6
195
Orlando
I have a buddy who works at a Lincoln Mercury dealer who also knows a tech that is seasoned when it comes to installing gears. I told him i was interested and my buddy told me the tech would install a set of 3.73's out of a Navigator 8.8 rear end with relatively low miles on the gears. So i figure i would buy a bearing rebuild kit and a clutch pack rebuild kit and give them to him and be done with it. What do you guys think about this? I was a little skeptical, but i dunno. Does this check out?
thanks
I'd replace the traction-lock (Ford) with something a bit stronger, like an Auburn. If you don't want to try their locker, they have a good limited-slip cone-clutch rear end that is far better than the wimpy limited slip in the stock rear end. With good slicks like MT's, the stock traction lock will be doing one-wheel burnouts pretty quickly... the auburn limited slip is a beast...
Lots of people have trouble with Auburn lockers. The 31 spline FRPP Trac-loc differential is very strong, and WAY cheaper than most other aftermarket setups.
I wouldn't put used gears in your diff either. Just buy new gears and have them installed, or buy 31 spline axles/diff.
thanks
Man go talk to Carlton at nationwide transmission on capital circle. He installed my gears about five years ago for $125 and he has done probably 100 mustang gear installs. He will tell you if you need it or not.
Ok i figure i will just get the gears and and do it myself at school with some help, i'm currently in an automotive class at a trade school. Anyway, i was doing some research and figure this is what i needed. Feel free to chime in on what you think.
8.8 rebuild kit from Motive
http://www.americanmuscle.com/rearendrebuild.html
3.73 gearset from Ford racing
http://www.buyfordracing.com/shop/product_info.php?sessId=59F84911DBE68E73E56CDBDDE07DDA23&products_id=459
Traction lok rebuild kit
http://www.blueovalindustries.com/products.php?pid=99012911
Ofcourse i'll pickup some gear oil locally, i figure i'll use what i used before which is some Valvoline 80-90w gear oil and the friction modifier. Sound good?
Well 2 of the 3 pieces to complete the rear end puzzle came today.
