Control arm bolts
If you can get me a pic, I have about 200lbs of bolts from probably 10 mustangs. I know I have control arm bolts in there, you can have em if you want to pay for shipping.
EDIT: You need 8 of these?
No, there are eight bolts and eight nuts.
4 control arms x 2 bolts and nuts each = 8 bolts and nuts
The lowers are aprocimately 105mm in length (get 110) and the uppers are approx. 82 mm (get 90). The size is M12-1.75. The nuts are grade 10.9 or better.
not that it helps on dimensions....but i went to ford and they wanted something insane for everything,36 bucks i think for all 16 pieces.... i paid 14 bucks at that part store for something similar. grade 10.9..
Similar, but *not* the same! :) The Ford bolts are coated to help reduce corrosion. If your junking the car within 5 years, then go with the regular 10.9 bolts. Otherwise, get the *correct* bolts.
wouldn't zapping the bolts and threads w/ either primer or paint cause a bigger problem later if you ever need to replace them again?
i know you could always use a torch to help release the nuts from the bolt, but why do that if you can make it easier on yourself now by buying the correct bolt and nut now?
Ford told me they were discontinued.
Painting them is not the same. Then, just get the bolts from the link that I posted at the top of the page.
http://www.breezeautomotive.com/details.php?prod_id=170&cat_id=34
These are OEM Ford, Class 10.9 Flange Bolts with anti-corrosion finish.
I know that some of the stuff I got from him did come in sealed Ford packages. He may have stock or access to the discontinued bolts. There is also a company that specializes in buying discontinued parts from Ford (at a deep discount) and then selling them. It clears out stock and space for Ford, the company makes money, and people can still get some parts (the parts don't just go into the trash). So, it works out for everyone.
