side exit exhaust
That looks awesome. I'm afraid to try that on mine though with the high compression engine. Its pretty freakin nasty at idle. :P
I was thinking of doing something similar but a mix of your guys setups. Put some electric cutouts that would Y into the exhaust.
iapexl8r,
That looks like an awesome set up! Any more pictures of how you worked the side exits around your subframe connectors?
Also, I would love a sound clip when you get the installation finished.
Tim
yea I hear ya on the compression @ 12 to 1 and a big cam, I run a solid roller with .660" lift on both exhaust and intake and I should be firing it up with the boom tubes installed tomorrow. I will get more pics up tomorow nite and will try a vid with sound too. would have had it done last week but I ran out of gas for my mig then had to take the labor day weekend off to get some partying done chris
got it final installed today. heres pics
The area of the boom tube that is cutaway is for the leaf spring wanted to make sure it wasnt going to come in contact with the boom tube. made vid put on you tube not to sure if sound came out will post it later if it did. chris
they would probably look good on sombodys mustang but not on mine, thats more of a hot/rat rod kinda thing. + iwould probably burn my leg @ some point.
Lookin good man (much better than Lake pipes, just not for Mustangs in my opinion..)!!!
Can you take some pics of full side shots, instead of close ups? I'd like to see what it looks like from a ways back...
Thanks!
Let's hear'em too! :nice:
I got my Hooker Super Comp Headers from eBay for about $150, the Dynomax mufflers were about another $100 for the pair one from eBay the other from Summit, and the tips were another $30 on eBay. I loaded up the mufflers and tips and drove over to a local shop that does alot of Hot Rods and cost me another $250 for the 2.25" pipe and to weld it all up. No problems whatsoever even with Subframe connectors and Traction bars, I have about 5" clearance under the tips.
