2002 mustang, stuck window
motorhead6776
ok so the driver side window in my 2002 mustang wont go up. the passenger window works fine. if i push the button up the motor dosent do anything if i push it down it clicks. the click is louder than the passenger window if you try to put it down once it is already down. what could be wrong and how do i fix it?
I had this same problem with my '04. Fod uses a stepper type window motor and when they go bad they loose one of the steps. You might be able to slam the door hard enough to get the rotor to skip and then it should go up. You'll have to get the motor replaced.
I Had The same thing happen 2 me about 2 weeks ago. i took the door panel off and beat on the motor with a rubber mallot while pushing the up button and it worked.
