After I get it installed and go back to the track I'll let everyone know how it helped...
I installed a BMR Upper Control Arm two years ago. (10 K miles) It is the one that is adjustable with the Spherical Bearing. It works fine but it is now noisy as is the usual case with sphirical bearing suspension components. Make absolute sure you torq everything to specs (130 ft lb) and check it periodicaly. The install is pretty straight forward, but lowering the fuel tank is a pain in the A$$.![]()
Good luck with the install...
thanks bigcat! So are you going to upgrade your UCA anytime soon? After I get it installed and go back to the track I'll let everyone know how it helped...
