Oil pressure went to zero on the mechanical gauge AND the stocker. Didn't hear any chatter as I immediately shut her down. I removed the oil pressure sending unit and had the wifey crank her over and not a drop spurted out.
Next, I remove the dizzy and checked the shaft. It looked ok, so I took a long screwdriver and nudged it to see if it was broke and I noticed it was very loose. Thinking it was broken I used a magnet to try to remove the shaft, and the magnet picked it up, but I couldn't pull it out the top, as it seemed like a washer or clip, was stopping it from coming out. Next thing you know...blip.. now I don't see it any more.
Don't know if it fell all they way through to the pan or not, but I do know its not where it should be. I guess its irrevelant anyway as the pump apparently stopped working.
Anyway what's involved in removing the oil pan to access the pump? Any tips from those who have done this will be appreciated.
I do have a Haynes manual but it doesn't really go into details on how to actually install the pump.
Thanks for the help.
BTW... sorry for the long post. I just installed my H/C/I combo and I'm a little down in the mouth.
