That is awesome. I want to go carb'd so bad. Kinda tired of the whole EFI thing. What kind of intake manifold did you use? Carb? Have you/are you going to sell all your EFI stuff? I'm curious how much you could get for it all.
Its the torker 2 single plane..... And yes I did go with a carb setup..... So far I have sold like 1000 bucks of the EFI including the Tweecer.... I still have some **** left...
Did you have to jet down the carb? 750 would dump a bit more fuel then I would like into a 302. A nice 650 Holley would run real well imho, I ran one on a 340 motor and throttle responds was perfect.
Just in case you powdercoat those hood pins, if they fit real tight right now, you might need to machine out the hole just a hair (to make room for the powdercoat build-up). It's easy to forget to do this and it makes the install a PITA later.
