i probly sound dumb askin this
Tom95gt
186
South Jersey
how do i got the front rotors off my 95. i looked at the rotors and they look like theyre one with the hubs but the rotors i got from the auto parts store are not like that. does it just look like that from all the rust or wut? im confused
Some times they rust on the hubs. I just hit them with a regular sludge inbetween the studs. That way you won't break the rotor, because I have done that before!! I put anti-seeze on the back side when I put them back together.
Too many CT's abound in this thread... Where's Tim or Daggar when you need them? :p
Soak them in some penetrating oil around the studs, give it an hour or so to eat away at the rust, go out, rotate them 180° and spray again. Give it a little bit to soak, and give them a smack. They should come right off at that point.
Don't forget, some of these cars still have the retaining clip on 'em. Tom95gt, check and see if there's a little e-clip on one of the wheel studs. They should be easy to see if you still have 'em installed. Ford put 'em on there to keep the brake rotor in place on the assembly line, they're not necessary anymore. You can pop 'em off with a screwdriver.
Otherwise, you'll have to be gay like turbogt..... :p
