front hub assembly
stuart415
if you over tighten the retainer nut on the front hub assembly is it possible to damage the new hub assembly or bearings just changed the driver side hub and now have the same groaning noise but sounds like it is coming from the pasenger side when I turn to the right the noise goes away also just had new tires put on could they be out of balance
yes used new retainer nut only replaced driver side possibly over torqued 40-50 ft pounds sounds like it is now the passenger side it is really bad around 55 mph when i turn to the let it goes away i thought maybe the new tires were not balanced but rotated back to front and still make groaning humming noise i could not get it alligned the same day my tires got put on they didnt have anything open tilll nov
.... you also said that now it sounds like the passenger side. So I would say that nothing is wrong with it if the noise is coming from the other side of the vehicle than the side you replaced the hub on. Maybe the passenger side is bad. :shrug:
