ROUGH IDLE
bonk707
I just put bbk long tube headers and off-road h-pipes on and now it sounds like it has a back fire and runs rough. The tube that ran to the OEM mid-pipe is the only thing I removed because there is no hook up can anybody help me and what is that line ? a smog pump line or vacuum.
If Roland69's comment about the plug wires doesn't help, then try the following...
See "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Does it only happen when the car is cold? the fact that the smog pump is just sucking ambient air should not be a problem. The smog pump really only assists emissions during start up. So when the engine is cold it pulls the warmer exhaust from the H pipe and tosses it back into the heads. So now its just pulling ambient temp air...and is not a vac leak or potential problem.
I think you should double check your plug wires...as this seems the most likely problem...esp if you just had all the plug wires off to change the headers.
Jrichker's surging idle checklist is also a great place to start.
Some review of how the thermactor air system works seems to be in order...
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps break down the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump draws air from an inlet filter in the front of the pump. The smog pump puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. Check valves located after the TAB & TAD solenoids prevent hot exhaust gases from damaging the control valves or pump in case of a backfire. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the dump valve at WOT (wide open throttle) minimizing engine drag. The dump valve reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT.
attachment.php
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid.
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
Some really good info. here.
I have a question. My TFS heads have the smog inserts in and I was wondering if I can re-route the line from the diverter valve to heads and tie it in to the line to the cats.
I want to run my smog equipment, but don't have the means to pull the inserts out without removing the heads. Will this cause any issues by bypassing the cold air from the pump to the cats?
Do it in a more simple fashon. Remove the diverter valve (the one with 3 connections) and simply run the large rubber hose from the bypass valve to the check valve on the pipe that goes to the cats. This way, air is constantly supplied to the cat converters except when the system shuts off at WOT. The vacuum line that used to work the diverter valve will need to be plugged. Make sure that blocking plates that cover the air input passages on the back of the heads are installed.
If you take the car for smog tests, make sure that you keep the engine running all the time you are waiting. When the cats get cold, putting air in them does not help reduce emissions. Leaving the engine running makes sure the engine and cats are hot and up to operating temperature.
Thanks for the fast reply jrichker! That is an excellent idea, I will do just that.
Now as far as the block plates. I'm not sure I follow. I remember we used threaded inserts in the holes and you can shine a light in them and it appears that they are sealed. I ran it like that for a while before this new combo with no problems. There is no carbon buildup so that would lead me to think it is still sealed off. Am I ok?
Thanks again.
