On my stock '88 5.0, I'm getting a little bit of hesitation on hard acceleration and I just put a fuel pressure gauge on the shrader valve on the rail. At idle, I'm getting 30 psi with the vac line on, and 40 psi with the line off. When I rev it to 4000 rpm's (with the vac line back on), the fuel pressure moves up to about 33-35 psi. Should it be higher than this? Also, when I tuen the car off, the psi immediately goes to 0. Does it sound like a bad pump or fpr, or both?
