What about using a cobra booster?
http://cgi.ebay.com/ebaymotors/1993...ryZ33566QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
I heard a lot of road racers like to use these for increased stopping power. has this ever been tried on an early car? Ultrastang, are you saying the 2.3L booster is a good choice for 4 wheel disc 65/66 cars, especially over the 5.0L unit? are any pedal mods required for the early cars? I saw your website for 67-up but can't find where the 65-66 needs modification (if any)
I've never attempted a Cobra booster in an early body. It's a good bit bigger than the Fox 5.0L booster:
'93-'95 Cobra booster on left, Fox 5.0L/ (and 2.3L convertible) booster on right:
http://img523.imageshack.us/img523/703/cobravs50lbrakeboosterao9.png
The '93 (Fox) Cobra R was the first Mustang to use this booster (as well as the 13" Cobra 5-lug front rotors and 11.65" Cobra 5-lug rear rotors before they became standard-issue in the SN95 Cobras). The Fox body doesn't have a problem with clearance to the strut tower in regards to MCs, but the Fox bodies had to have a dent knocked into the strut tower to clear the larger Cobra vacuum boosters.
With the early bodies, the problem is with the shock tower in relation to the MC. The booster and MC, combined, (on a '67-'70), has to have a combined length kept to within ~14½" overall to clear the shock tower. --'65/'66 Mustangs are near the same --maybe a little less due to the larger bulge of the lower portion of the shock tower compared to '67-up.
The 2.3L and 5.0L booster work about equally as well. The 5.0L booster is smaller in diameter, but is thicker than the 2.3L version. The 5.0L booster (in a '67-up at least), gives more room around it to install a hydraulic clutch MC, or to use the stock mechanical linkages (or even a cable clutch), you have to take the length of MC into consideration to clear the shock tower if using the (thicker)5.0L booster.
A 2.3L booster will not pose a problem with any MC, so long as the flange of the MC will bolt to the mounting studs of the booster.
Typical dual bowl Ford MC lengths are ~7½" long. This will fit in a '65-'70 Mustang with either style (2.3L or 5.0L) booster with no problems. A Mk VII/SVO MC, on the other hand, is ~8-1/8" long. This is too long to use on a 5.0L booster in a '65/'66, but I did get this combination to fit in my '68:
http://img503.imageshack.us/img503/5806/foxboostermkviisn95mc00cd5.jpg
I had to radius the left front edge of the protrusion on the tip of the Mk VII MC, and it's a close fit, but does not touch the back of the shock tower.
On a '65/'66 pedal, you would have to move the brake pedal pin downward ~ 1¼" and back 3/8" from the front edge of the pedal's upright to line up with the input rod of the 2.3L or 5.0L brake booster.
It's best to fabricate a reinforcement plate to weld to the front of the '65/'66's pedal support to add strength to the firewall to reduce firewall flex when the brake pedal is being applied. '67-'70 models have the advantage of an extra panel layer in this area for strength, and a plate is not as critical, but this is what the plate looks like that I made for my '68's pedal support --with the Fox booster's stud pattern drilled into it (2.3L and 5.0L booster stud pattern is the same) :
Reinforcement plate for '67/'68 Mustang:
http://img513.imageshack.us/img513/2977/foxbrakeboostertemplateat1.jpg
Face of '67/'68 pedal support (unmodified on left, modified on right:
http://www.ultrastang.com/Images/Scanned/Sept2002/12.jpg
Plate welded to face of pedal support:
http://img503.imageshack.us/img503/2629/68pedalsuppoert002fw6.jpg
Pedal support painted:
http://img513.imageshack.us/img513/6913/68pedalsuppoert003wi0.jpg
A plate for a '65/'66 would not look like the one I made for my '68's pedal support, but you get the general idea.
There aren't many choices for boosters that can be used with dual-bowl MCs on '65/'66 models that work as effectively as the Fox boosters. In the case of the '67-up Mustangs, a stock booster is obviously the easiest to install over the Fox booster, since they require no modifications to the firewall/pedal support, but at the time I did this conversion on my '68, I didn't have a stock '68 brake booster, but I did have a Fox 5.0L booster lying around.
