What are your cylinder pressures? When I got my engine redone my pressures were at 190+ and my car dynoed 330 - 357, it has not felt as strong for the last few months, Ran a comp. test all of my cylinders are at 173+ this is doing a wet and dry test. The car is using NO oil, everything else is the same. Went a step further and took it into my tuner for a few dyno pulls, my numbers came back horrible. I had a few rocker studs break on me, and I replaced all of them with new ARP studs, readjusted my rockers and even put in new pushrods just in case I had bent one. My car idles fine, runs fine, no bent valves, but my numbers came back waaaaayyyyyy lower. I got a print out this time for ya grady. My A/F is good..... I'm at a loss. No vaccuume leaks, no exhaust leaks, timing is set right at 14* car pulls fine, but only to 6k rpm's before dropping, before they started to drop right about 6300 rpm. This is starting to wear thin on my nerves.
<a href="http://photobucket.com" target="_blank"><img src="http://i143.photobucket.com/albums/r155/THEMIXR/dyno001.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
