ok i will be running patriot 185 heads, with the 2.02/1.6 valves, i will use a .051 thick HG to try and lower compression.
i also want to use an f-cam with 1.7 rockers, with this combo do you think the valves will clear enough to not cause any problems??
i will check for sure but i am just wanting to get an idea on here before i start buying parts. it it does hit i will have to get a 1.6 rocker it outa clear then. with the thicker HG i should be able to clear if it hits with the 1.7s
j/k
