supercharger ?'s
1.) what are you looking to spend?
2.) what are your goals for the car?
3.) what other mods are on the car now?[/QUOTE
- All said and done i can really only spend about 3,300 to about 3,600, i dont really have any "set" goals for the car i have wanted to get a sc for it since i bought the car, i have a king cobra clutch, bbk shorty headers, bbk h-pipe, single chamber flowmasters, 3.73 rear, and a drop in k&n air filter.
Send me a messege back and let me know what you think. Thanks
Vortech S-trim. Pretty much complete and later you can get bigger injectors and ditch the FMU. Fits your budget and you could probably buy some guages to monitor fuel and boost as well.
personally, i'd probably go with something like a novi 1000, maybe a set of used gt40 heads (or better if $$ permits), better intake, & remember you also should get a bigger maf, tb, injectors, fuel pump. i always recommend SFC's to anyone who doesn't have them also. best mod for the $$$ imho. You'd probably come a few hundie under budget with the combo i listed, and over 300 rwhp....
you could also do a Kenne Belle roots style blower for insane low rpm torque, but it's not something i know much about.... except that it's an instant torque monster on the streets.......
i've been checking out smaller centrifugal SC's for a while, as this is the route i'd like to go personally; with a smaller blower (maybe 5-8 psi) and upgrade the heads cam and intake also.
Just something to think about, When you add heads and anything that will make the engine flow better the boost will go down. In turn you will find yourself wanting more and buying pullies and the supporting hardware for elevated boost. Anything over 6psi( some will say you should anyway)will requre a bypass valve not included in the base kits. You may need to retard your timing to avoid pinging and a BTM does not come in the base kits either. I have gone the entry level route on my old car and I can say with out a doubt 5-6psi will be fun for a short time and then you will want more. The supporting hardware costs alot more when it is bought outside of the kit.
If you dont mind building it up a little at a time then go that route. As bloopbloob said, adding heads will be a good idea and you must figure in the added cost for all the little things as well as the gaskets and additional down time. I have been there and found out that it is best to bite off only what you feel like you can handle. Just do a little research and make sure you know what your getting in to and getting what you want. One more vote on the frame connectors as well.
What size injectors would you need with a Vortech S-trim?
Would you need an intercooler running 8-10 psi?
Check out the latest issue of Modified Mustangs.
It has some good information on the myths of supercharger.
if your engine is stock or close to it, you could probably run the stock 19s with the FMU and make it get by but its not the ideal way to do it. i would ditch the FMU and get soem bigger injectors like 36s or 42s and get a tune to make it run well.
i bought my vortech base kit. has the sc trim blower and all the stuff, my kit didnt come with a t-rex booster fuel pump( already have 190 pump) or the bypass setup. i paid 2k even for the kit brand new
out of the box with stock pullies it make 5 psi.
ran great and helped out a lot. i bought a UPR boostmaster pipe for 125
boost went to 6 psi and i could tell a small difference. made a bit more power.
then i added a bypass valve. instead of buying the alum tube with the threads in it like most people do. i bought a standard bypass vavle from bosch. same as the s trim kits, i got some heater hose to fit it. then i drilled a hole in my black plastic tube and bought a plastic barb fitting to hook the hose up to. i epoxied the fitting into the plastic tube. then i ran the hose, the UPR pipe has a nipple for a bypass. i routed it there. works like it should and i only have like 90 bucks in it, 80 for the valve and a few bucks for the hose and etc to plumb it up.
then i added a 7 inch crank pulley and it jumped to 9 psi. that only cost 150
so i didnt have to spend much to get the extra power
i like the base kit but if i would do it again i would have got the s trim kit to start out, has all the extra goodies and makes 8-10 psi out of the box.
i really like my SC trim kit but the 5-6 psi is just a **** tease and i wanted more boost shortly after. get the s trim kit, you cant go wrong!
More specs on the engine would be helpful, but like foxfan said 42's would work fine. No intercooler for me and Ive seen up to 16 psi. Plenty of supercharged cars running around without a intercooler at 18 psi or so. Meth wouldnt be a bad idea though either.
Sorry , I forgot to post my car set up.
What is the FMU?
Thanks!
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
I would say your safest bet would be a set of 36's and update your mass air to match. I would also throw in a 255 in the tank and ditch the idea of ever running an FMU. Set your timing at 10 degrees and pop in a set of Autolite 23's gapped at .035 and that should keep you safe to atleast 8 psi. You also may want to look at an ignition system with a bit stronger spark and a rev-limiter, missed shifts at 6,000 are hell on parts!
The FMU is a bandaid, It shuts down the return line while in boost and elevates the fuel pressure in turn making your fuel injectors act bigger. It works but a custom tune with larger injectors would be alot better.
