Trick Flow
19Stangnotch87
74
idaho
Wats up guys i am thinking about changing my intake manifold on my 03 gt and was curious if anyone has the trick Flow Track heat?
Well if anyone has it tell me a lil about and if it a good power adder or wat?
i was also interested in that manifold as well. for a bolt-on car?
does it perform as well as a bullit manifold?
reason being it looks like a direct copy of the bullit and you don't need as many random parts to make it work. alt, throttle cable, fuel rails, Throttle body.
i would love to go with the p-51 but the fuel rail kit pushes it to more than i want to put in a part like that
Aftermarket intake manifolds usually are recommenced on FI stangs(better gains), bolt-on ones will not net you much? Like the 01 Bullit and gt at the time. The only difference was the intake manifold the bullit had over the gt and it only produced 5 more hp over the gt. If you go FI in the future, then it wouldn't be bad to invest in one.
on a N/A car it wont be worth anything.
most s/c cars are seeing little to no gains from the TF. a P51 is about the only one i would recomend.
FWIW i have $650 in my P51 and the CPR rails
wow thats a great deal thats around half price i would get one for that much but i can justify paying 1200 bucks to get one.
bullit manifold have proven to pick up .2 in the 1/4 same as long tube headers. so are they that worthless?
under the curve power
Depends on your future mods as well. Plan a combination of mods that work well together and you will see better results. No doubt the curve power will be better, but I would get that only if I was going FI. Your stock manifold works just fine with bolt-ons.(If your headed in that direction.)
i bought a tf intake along with some patriot heads,bbk long tubes etc. and will be putting them in about 2 week... will let you know the details. i can tell you one thing, its got some weight to it
yeah i all ready have all bolt ons gears and a tune, except lts. and i have a vacumn leak somewhere in the manifold area. so i figured i would try to tear it all apart up there and get something new and better at the same time.
the old 2 for one deal so to speak. but the bullit is too hard to source parts to make everything work together, and the p-51 is a lil too much because of having to buy the fuel rail kit, and the trickflow has no real world results yet. so i kind of dont know what to go with.
