Drive shaft bolt size
Not sure that it would help since I dont know the size but they are available from Ford dealers for not too much money. They're considered semi-sacrificial, hence often being in stock. I'd use the exact-right bolt on an application like this. They come with threadlock on them.
Good luck.
I went to ford and got some bolts for the drive shaft. Now im having trouble getting a torque wrench on them. Any thoughts on the best way to torque these bolts down.
later
Orlie
I've had luck using a short extension. IIRC, the spec is fairly broad.
