piston cleanup question
Ok so I need to clean my pistons. Both books I have say I need to clean the carbon off the top of the piston and the ring grooves. What about the sides of the piston between the rings? There is a lot of buildup there as well. How should I clean that off...?:shrug:
sweet, i'm going out right now to pick some up!
I have my cam and lifters coming soon so when I clean the pistons I should be able to reassemble.
Oh another question...If the main bolt and rod bearings look good, should they be replaced anyway? Same with the cam bearings?
DO NOT USE OVEN CLEANER ON ALUMINUM PISTONS!!!!!!!!! Unless you want em to disappear. To clean the ring grooves, take one of the rings that came from them, break it in half and use it to scrape the carbon out of the grooves. The tops can be wire brushed. I use a bench grinder fitted with a brush wheel to do parts cleaning
exactly how i do it as well.
well, i don't think it matters now anyway because i think i'm gonna have to have the cylinders bored...
Might as well go .03 over now and get new pistons...:mad:
oh and could you guys take a look at the block picture I have. I don't know if this broken bolt hole will affect anything much but if it does, can it be fixed?
If not, should I just junk the engine?
I am not sure about your broken bolt thread, but having the block bored shouldn't be more than 150 bucks. I know many other people have had that broken thread before and have fixed it by welding the piece back on and having it re-tapped or something.
That looks like the lower bell bolt, it's probably best left as is, you've got 5 others plus the two alignment pins to keep the bell aligned & tight to the block. Also be a good excuse to look for a roller block too. What's the block's casting numbers ?
I definitely don't want to get a brand new block. This is a learning block for me. It's a 69 351w with '70 351w heads. It's going in my 65 mustang.
I thought boring cost a whole heck of a lot more than 150 bucks...
Where can I get some info on machining and costs?
As for the broken bolt hole, I guess I'll just leave it if it won't harm anything.
My bud also recommended welding a washer to it.
Anyone know how good the summitracing pistons are? The ones that cost 89 bucks for a whole set?
What a great forum:SNSign: :nice:
EDIT. Oops, I just saw that you have a 351 block, I thought at first you had a 302 block with 351 heads. Summit pistons are probably ok if you are doing a beginner/cheap/learning build, some of their stuff is good, some isn't, but their pistons are probably good.
I think with machining, you'll have to check local machine shops for pricing. Ask them if they use a torque plate when they bore, because they should. They will need your block with the main caps, and if they are a good shop, they will ask for one of the pistons that will be going into the block as well so they can do it more accurately. I paid $110 to have my 302 done, but that was about 5-6 years ago. Good luck on the build!
Ok,
So I've decided I'm gonna scrap this 351w project because I can get another 351w 69 block that was already rebuild and bored for, I'm hoping, 300-400 bucks.
It has a torque cam and pretty much would be ready to go once I get my heads all set.
I'll probably sell my damaged 351w and my other 302 to pay for this 351 heh.
What do you guys think?
