fuse question
See here.
Fuse 16 might be what you're after. I'd imagine that the circuit you choose should only be hot with the key on. Be sure to check that.
Good luck.
See here.
Good luck.
Yeah I was wondering if it was hot or not but that is what the instruction manual that came with the Vortech said to hook it up. It said "hook to ciagr lighter fused side at fuse box is the perferred location" would the fused side still be number 16?
The find the fused side: Pull the fuse and put a test light on each terminal where the fuse plugs in. One terminal will show 12 volts and one will not. The side not showing 12 volts is the fused side (it is protected by the fuse).
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
