- Aug 12, 2006
- 18
- 0
- 0
My car cannot sit for more than 4-5 days without my battery dieing. Is there an easy fix to this?
Mine did this too for a while. It was the multi-disc changer in the radio. For some reason it would get a mind of its own and want to start changing slots with no cds in it. My friend had a F-150 same problem. You can tell by hooking the charger up to the battery and if you hear it clicking and wont stop thats the problem. If your car is still under warranty you can have a dealership perform a electrical drain test on the system. Only other fix is to put in a voltage stop monitor right off the battery. This is of course thinking the battery is still good and hasnt started to die on you.
Actually, the disc cycling is because the car has power again. It is not the cause of the problem.
The cause is the amplifiers for the Shaker. Also, these cars take quite a bit to crank. So if the battery is at all low, trying to start it will kill it. To stop this from happening, I make sure to turn off my stereo before opening the door. Seems to work.
If you're really bothered, you could always leave it on a battery tender.
