classic boost Founding Member Feb 3, 1999 709 0 0 canton, oh Mar 7, 2008 #1 Mar 7, 2008 #1 think i can weld it up and grind it down?
mrmustangman357 Member Feb 11, 2007 763 3 18 Mar 7, 2008 #2 Mar 7, 2008 #2 detonation anyone? did it wreck the block too?
NasaGT Founding Member Sep 19, 2002 1,993 2 49 Virginia Mar 7, 2008 #4 Mar 7, 2008 #4 A little JB Weld and you'll be running again in no time.
Vinyl66 Member Mar 21, 2004 398 0 16 Mar 7, 2008 #5 Mar 7, 2008 #5 Yeah JB weld should fix it up fine. That sucks man! What do you think was the mode of failure? Too little fuel flow, too much timing, too little octane, combination......?
classic boost Founding Member Feb 3, 1999 709 0 0 canton, oh Mar 7, 2008 #7 Mar 7, 2008 #7 too little fuel. it started going lean on me for some reason. the bore has alot of slag on it, but doesn't seem to be ruined.
Fast63 New Member Sep 20, 2007 717 0 0 Mar 7, 2008 #8 Mar 7, 2008 #8 wow, it looks like someone took a torch too it. What kind of pistons are those?
iskwezm 10 Year Member May 24, 2005 4,159 20 79 Rowland Heights,California Mar 7, 2008 #9 Mar 7, 2008 #9 PUUUURLY cosmetic, just slap it back in.
Edbert Founding Member Jul 13, 2002 3,548 32 109 Austin TX Mar 7, 2008 #10 Mar 7, 2008 #10 It's just a flesh-wound!
mrmustangman357 Member Feb 11, 2007 763 3 18 Mar 7, 2008 #11 Mar 7, 2008 #11 did you drive home on it?
classic boost Founding Member Feb 3, 1999 709 0 0 canton, oh Mar 7, 2008 #12 Mar 7, 2008 #12 it's a j&e srp piston. and yes, i drove it home (smoked like a train).
M mikethebike Member Jun 12, 2007 358 0 17 Greenville, SC Mar 7, 2008 #13 Mar 7, 2008 #13 That'sust nasty.
mrmustangman357 Member Feb 11, 2007 763 3 18 Mar 7, 2008 #14 Mar 7, 2008 #14 so i would like to know, when did you figure out you blew a hole in your piston, as opposed to kissed valves, etc. do you have a pic of the bore? I'd like to see that too if you got one. NASTY!
65ShelbyClone Founding Member Sep 9, 2000 4,675 38 119 Antelope Valley, SoCal Mar 7, 2008 #15 Mar 7, 2008 #15 Well there's your problem!
Fast63 New Member Sep 20, 2007 717 0 0 Mar 8, 2008 #16 Mar 8, 2008 #16 65ShelbyClone said: Well there's your problem! Click to expand...
F farmboy89 New Member Apr 8, 2007 38 0 0 Mar 8, 2008 #17 Mar 8, 2008 #17 that right there is a good one
12sec67 Active Member Oct 6, 2003 1,301 1 36 San Diego, Ca Mar 10, 2008 #18 Mar 10, 2008 #18 wow, you almost had me beat! How are the heads? I didn't drive mine home the day mine went but I still had to deck the heads from the detonation pitting the heads.
C C0V3R Member Feb 14, 2003 524 0 16 Australia Mar 10, 2008 #19 Mar 10, 2008 #19 I'm impressed it kept going
classic boost Founding Member Feb 3, 1999 709 0 0 canton, oh Mar 10, 2008 #20 Mar 10, 2008 #20 C0V3R said: I'm impressed it kept going Click to expand... didn't even make a sound the whole ride home. just purred along (and smoke like an oil field fire).
