wat times SHOULD i be running?
yeah i was kinda worried about running out of gears too...i guess ill find out if i need to go to 3.73 or not too lol
coil packs worth it or is that basically a waste of $500?
Not worht $500. I imagine you are talking about the Grenatalli ones also, that name catches alot of ~~~~ around here.
Accel and MSD both have aftermarket coil packs now. Accel's are cheap ($30 a coil) and MSD's are a little more than that.
Dont bother replacing them unless they are worn out.
Also, you can run a 28" tall drag radial at the track if you wanted to. That will reduce your overall gear ratio a little lower than what it would normally be with 4.10's... and it will give you a little more MPH to play with at the track before you run out.
yeah i actually jus left JPC for any of u who kno where or wat that is and decided on centerforce instead of fidanza clutch/flywheel...the only suspension work i have is an eibach pro kit which yes i kno isnt nething really...i was talkin to justin (owner of JPC) and he was even telling me that i should have no problem hitting low 12s but really comes down to me to hit 11s since im driving...as far as the gearing i should b passing the finish line with jus enough left in 4th...might b pushing it but should b almost perfect...its not going to b impossible to hit high 11s if everything goes right
