? about headers
Yes, the BBK equal lengths work fine with stock H-pipe. I have them in the ceramic coated version. A pain to install but nice once they are in and sound great. If you get them shoot me a private messege and I can give you some tips to install them.
They will fit, but I believe they need an EGR connection on them, which is why they are specific to the different models.
One of the Sn-95 guys will confirm this.:)
Make sure to change your spark plugs when do the install because its the last time you will be able to access them after putting those headers on. At least without a bottle of KY, prayer, alcohol, and colorful language.
Adam
just put a set on mine about 2 mos ago. fit and run good no leaks pain to install left side goes in from the bottom after you disconnect the steering shaft. right side goes in from the top. Also take the time to grind out the extra weld from inside the header ports before install for more flow
Colorful language is indeed to be expected.... removing those headers (installed by the previous owner) was by far the most difficult and annoying thing I've ever done on any car, and that includes dash removal. I took them out because they burnt-through 3 sets of plug wires (even burnt-through those protective wire boot covers). I strongly do not recommend them. And as mentioned, changing plugs quickly becomes a 2-3hr struggle instead of a quick 20-minute job.
