My car is a 1988 with 17,800 original miles and until spring 2007 was in storage since 1992. Before putting it away I had installed polyurethane sway bar and end link bushings, Koni adjustable shocks/struts and FMS c-springs. Everything else is stock -K-member, LCAs, LCA bushings, etc and from what I can tell all are fine with no cracking or damage. I remember it always riding like a buckboard but was very sure footed. When I started driving it again last year the surefootedness was gone and the car was all over the road at highway speeds and the steering felt heavy with very little steering wheel return to center.
I had MM caster camber plates installed along with an alignment to MM's specs. The car is much better but the steering is still heavy and doesn't center well and at anything over 60ish the front feels loose and I am correcting my direction, especially if there is some wear on the road.
I jacked up the car (one side at a time) yesterday when I had 5 minutes and with my hands at 3 and 9 there was a little play on both wheels. With my hands at 12 and 6 there was even more play and I could see the strut on the driver's side move. On both wheels, I could see the rotor moving inside the caliper but the caliper didn't seem to move at all.
Does this sound like something familiar? If I have to replace ball joints and tie rod ends, are there improved parts?
