the passenger rear side of my car sags quite a bit lower than the other side. i have sportlines and i hear this is a common issue. i have found a way to correct it by buying a set of rear adjustable lower control arms by granatelli. these allow you to raise or lower each side of the car to the desired ride height. with these, i can level out my rear stance.
http://www.granatellimotorsports.com/product_display.php?gid=127
while i am replacing the lowers, i would like to go ahead and replace the uppers as well. my question is can i mix and match upper and lower control arms without any negitive effects? the set of uppers are ford racing steel non adjustable with hard durometer rubber. the granatelli lowers have poly bushings. will this cause a problem ?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=FMS-M-5500-A&N=700+115&autoview=sku
