to :SNSign:
$1000 for a tune? Wow those are some expensive shops.
Do you have any mods done to the car and are you having any issues? We typically recommend creating a signature that lists your mods, also, as it can help with getting some help with the issues you're experiencing before we ask what the combo is. I'd highly recommend staying away from a carb, even though it can tend to be a much simpler setup when it comes to tuning. Ditching the EFI will lead to needing a fan controller, plus the remainder of the carb setup. Off the top of my head, the things I can think of that you'd need are an intake, carb, distributor, ignition system, new fuel pump, fuel pressure regulator, new lines (possibly from the tank all the way to the carb), and a fuel pickup from the tank. In parts alone, I could see you very quickly eclipsing the $1000 for the tune. Plus, you'd lose the benefits of EFI, being that it can adapt to changes on the fly without creating drivability problems. Being the red headed stepchild really only applies to the EEC setup, since anything that can be done to the Fox Mustangs can be applied to the SN95 models, engine wise.
I understand you're pretty strapped for time, since it sounds like you definitely have a lot on your plate currently, but if self-tuning sounds like something you'd be interested in, you could pick up a TwEECer RT, or Anderson PMS, a wideband, have an O2 sensor bung welded in, and a cheapo laptop off eBay for under a grand, if you do some shopping around. I picked up my TwEECer RT pretty cheap off eBay used, but in perfect condition. Got it for roughly the cost of the base model TwEECer. There's some very knowledgable guys here on the forum that can definitely help with a tune in one form or another. If the self-tuning isn't up your alley, there's a couple that could help get you going with a mail-order tune, also.
