Electric fan for fox?
2BADSTANGS
385
Colorado
I am looking to upgrade the cooling system on my '93 GT by adding an electric fan. Are there any in our fox bodied brethern (Mark VIII's etc) that are an easy pull& swap? Also can you use their wiring or is there any place that sells a harness to accomplish this? Anyone done this that can give some first hand tips? Thanks!
If you don't have a high current alternator, you can forget about using the fan. The stock 65 amp alternator isn't big enough to run the fan and the rest of the car.
Switching a fan on and off manually is a bad idea. Too many guys have been distracted (hot girl kissing on their neck, too much to drink, dog tired and not thinking clearly) and cooked things because they forgot to flip the switch. An equal number have forgotten to turn the switch off for the same reasons and run down their battery.
The best fan controller available today is a DC Control unit. www.dccontrol.com. Cost is about $110. Be prepared to wait 4 weeks or more to receive your controller once you have sent in your payment. The controllers are custom made in small lots and lead times can stretch out.
Next best is a SPAL controller - $70-$90 See http://www.spalusa.com/fans/automated/accessories/fanpwm.html. Ebay will have the controllers for the $70: do a google search and see what you find.
At the bottom are the Hayden or Imperial controllers available through Advance Discount Auto Parts and AutoZone. The non adjustable one is about $30 ( Hayden 226206) and the adjustable one is about $60 (Hayden 226204). I recommend you do a Google search on Hayden and the part number for more info.
Do not use a simple on/off switch without using a relay. The current load can burn up the typical cheap automotive switch very quickly. The fan draws 30+amps and you need to use #10 wire on the fan power and ground wiring.
If you are good with electrical stuff (90% of the people here aren't), build your own controller. The numbers on the diagram (#86, #87, etc) refer to the numbers on the bottom of a typical automotive relay.
attachment.php
Note that the temp sensor in the diagram isn’t really suited for the job. You’ll have to do a Google search and find your own.
This version of the fan controller will continue to run the fan after the ignition switch is turned off, just like most new cars.
To allow the ignition switch to control the fan so that it does not run when the ignition is off, connect the relay contact #86 to the red/green wire on the ignition coil or to the red/yellow wire on the coolant level sensor.
If you are an experienced electronics tech or electrical engineer, email me and I will send you the prototype drawings of a fan controller that is probably as good as the DC Control unit. It is a build it, troubleshoot it yourself item. I will not build or troubleshoot units, so it is not suitable for anyone who isn't really good with electronics.
Alternate placement for a temp gauge sender or temp switch/temp sensor for an electric fan. Use the heater feed that comes off the intake manifold. Cut the rubber hose that connects the manifold water feed to the heater and splice in a tee adapter for the temp gauge sender. Be sure to use the same water feed line as the ECT sensor. That way you will get the most accurate temp readings.
Tee adapter info:
Make a pilgrimage to your local hardware or home supply center and get some copper pipe and a tee that fits the temp gauge sender. Solder two pieces of copper pipe onto a copper pipe tee with threads in the tee part. Find the correct brass fitting to match the temp sender threads to the tee fitting.
attachment.php
Sweet, thanks for the schematic. Luckily, I happen to be pretty good with the electronics. (1st class MECP certified) Can you tag into the factory coolant sensor or will the power being fed through the coil of the relay throw off your temp. sensor?
There is no on/off switch action for the factory sensor, it is a thermistor (resistor that varies resistance according to heat). In order to use it for anything but driving the indicator, you wold need a buffer amplifier to isolate the extra load from the indicator circuit.
