Idle Issues??
asecretfile
228
I went through the surging checklist but heres what Im dealing with
87 GT mass air converted, just replaced the heads
My car will idle ok with no missing at throttle up as long as I either have my MAF unplugged, or my IAC unplugged
Dumped codes engine running and got 98 and 66
heres a little video of what it does when I plug in the MAF
stalls.flv - Video - Photobucket - Video and Image Hosting
Here's what Ive replaced and checked
replaced IAC and checked voltages
Replaced MAF twice
checked TPS as well as MAF voltages and resistance
sprayed for vacuum leaks
replaced upper to lower intake gasket
cleaned throttle body and where the IAC bolts up
double checked my engine and intake grounds
If I had a bad injector how would I isolate it? Or better yet if I had one that was bad, wouldnt it still be affected with my MAF unplugged
any help would be appreciated :nice:
Clear the codes and dump them again to make sure the code 66 (MAF) fault) is due to a MAF problem and not your unplugging it. If you still get a code 66, your wiring is suspect. Check the MAF voltages against the table in the Code 66 test path.
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
Changes in RPM causes the airflow to increase or decease, changing the voltage output.. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and ground. Make your measurement with the MAF disconnected from the wiring harness.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Fuse panel layout
Vacuum routing
If it all checks out, then the odd are you have a vacuum leak. Use a vacuum gauge to check the vacuum at 1000 RPM. You should see 18"-21" of vacuum with a stock camshaft.
Upon looking around I noticed my hego ground that goes to the back of the engine to be in rough shape (just replaced the heads). Could that be causing symptoms like this giving the EEC bad o2 readings? I havent had a chance to get to it yet
thanks
thanks
Yes. It will definitely affect the O2 sensor operation.
