pepboys, autozone, kragen, napa all have ramps you can buy they range anywhere from 25-40 bucks. U can also drive the car up on the sidewalk, crawl under the car and break the torque on the oil pan drain plug then lightl tighten it back up. drive the car into your driveway or garage and use your jack from the trunk and lift the car just enough to get your arm under the car with a extension (dont get completely under the car) place the drip pan under the drain hole and remove the drain plug the lower the car to the point where it is almost ontop of the drip pan and be done with it.
