Does anyone know of any tweecer tuners in the ny area? I have called a bunch of places and they say they dont work with the tweecer. I cant figure it out for the life of me and I need this thing up and running already.
The part I was referring to with timing is to make sure you don't beat on the car with a stock timing table. You'll prob get detonation that way The stock timing table is way too high for a boosted car.an overly rich mixture will cause idle surge which is common on a stock tune computer with larger injectors etc etc
so before "curing the surging idle" i would do as suggested above and work with the MAF and injector settings, once the AFRs start getting where they should be. chances are the idle surge will go away.
for the timing i would lock out the timing to 17-18 total in the "WOT spark advance vs RPM" function. that should keep things safe when WOT, until you get around to rescaling the load based tables... once you rescale the load table you will have to go back and rescale the values in the tables. or else you will have way too much timing at part throttle.
If I recall correctly, the eec will use the lowest timing value out of all the tables for wot, right? Also, I don't have my laptop to check, but isn't there a scalar that allows you to only use the primary spark table and disable wot vs ect, act, rpm?
