V-8 mounts
There are a set on e bay, http://cgi.ebay.com/ebaymotors/1974...022QQitemZ350091160728QQrdZ1QQsspagenameZWDVW Never used but repainted, they look like old stock which may mean the rubber is drying out. They are way over priced and still have 2 days of bidding to go.
My choice was to buy a rebuild kit from a gentalman named Brett who had designed and found a manufacturer to produce rebuild kits using the proper density urathane cushions. I purchased a set and can tell you they are great. Easy to rebuild all parts are included and work great for around $100.00. He also sells complete sets already assembled for around $200.00. Here are photos of mine prior to install.
You can find Brett on Mustang II forums .net http://www.mustangii.net/forums/default.asp
V8 Mounts?
Can some one tell me how to tell the difference between the 4 cyl and the 8 cyl mounts. I was told I needed the V8 ones. When I removed mine, they look similar except the rubber. One is a solid piece and the other has two put together. Thanks for any help.
