I assume this is a compound wound motor - what is it's rating in HP and what is it's peak TQ?
No, it is series wound. Compound wound motors require the use of controllers that are not commonly available. They are usually designed for a specific motor. Series wound motors work with most any PWM current source.
There are not any specs available for this particular GE motor. The performance should be similar to this motor http://www.evsource.com/tls_warp11.php. This is a new motor patterned after the GE design that I have.
Don't be deceived by the numbers, you really cannot compare them directly to ICE numbers.
-enganear
