SERIOUS TECH HELP!
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
Ok so i'm doing my 351, my question is... if i take my 76MM C&L to work and bore it out to 80MM is it possible? and also if it is can i just get the 42# tube for it and roll? Also same perspective on my throttle body. Can i bore it out to 75MM? I was gonna take it apart and bore it then remake a butterfly for it. It's a accufab throttle body. It looks like the stock butterfly is brass or bronze? it's a gold color so do i need to make the butterfly out of the same materal or can it be mild steel?peace
john:p
John,
I don't know exactly where you live, but if you bore out your MAF I will find out where you live, and beat you with the MAF meter :eek:
If funds are driving this choice, then look at a Moates.net tuner for ~160, and LMAF for about $90.
Sell the C&L to recover some of the costs...
I would discourage the machining of the TB as well.
Way too much work for what you would get back.
Sell what you have, and buy something better...
Maybe others will disagree :shrug:
John,
:lol: want me to tell you? ok i was seeing the LMAF for wayyyy more but cool thanks for the link! peace
john:p
For the most part, modifying a MAF meter in any way is a bad idea, and the C&L unit is supposed to be inconsistent to begin with. You just run the risk of getting bad airflow readings.
... But I think the TB is a cool idea. If you are good with a Bridgeport, and have free time/materials at work, why not? I made tons of car parts for myself while I had access to a machine shop. Accufab parts are expensive to replace, too. The only issue I can foresee is the butterfly bearings and seals, as you'd probably need to find a way to move them outward with the increase in bore size. I once made an EGR spacer from billet aluminum; I can't see hogging out a TB being too much more difficult. I imagine the butterfly should not be made from steel for corrosion reasons, but some sort of stainless might work. I do think the factory ones are brass, but maybe its a coating that gives it that color.
i build saw mill equiptment so even if i had to i could probably get new seals and bearings from our vender. whats everyones opinion on what a farly new 70MM polished accufab T.B (for fox) and the 76MM C&L worth. I just dont have the tube for the C&L i sold it with the motor for the 24's. peace
john:p
