I am building a 289 for a Cobra replicar and currently have the engine assembled minus the ignition. The original engine did not have a "useable"distributor when I received it (seized and bent) so I am looking into my options. This being said, I don't have plans to buy an OEM distributor and upgrading to the Pertronix kit but was looking at either the Davis Unified Ignition HEI or a MSD type with the control box and external coil. I like the Davis as they actually curve the distributor for you given you supply them with cam info, vehicle weight, trans type etc. I had an MSD billet distributor. flamethrower coil and 6AL box in my 66 coupe and it worked fine. Has anyone used a full mechanical advance Davis Unified system or similar and what were your likes/dislikes? I dont want to have to go thru the expense of the additional "addons' with the MSD setup (needing a coil and spark box) and am really liking the HEI style for simplicity. Thanks, Brian
There are far more & better looking choices than the DUI distributor.
