Opentracker
20+ Year Stangneter
- Feb 4, 2004
- 516
- 0
- 16
I had one of those K8158 here to look at. It has grease fittings at each end and will not take a roller kit. I tried to move the drag link end of the thing (right side) and I couldn't. I'm not sure what they have in there. If I wanted a roller idler arm on a later car, I would use two roller kits with an original type arm. One at each end. I believe the bushings are diffenent at each end, so it would take two different kits. The K8158 would have more bind than a true roller bearing arm IMO. With that said, the K8158 would have to be better than an early style arm from a daily driver standpoint. If someone has a used idler arm from a 67-68 Mustang, I could use one for some R&D work.
John
so i can attach some rubber bushings with a bolt or something and make it less noticeable, smae with the upper shock mounts too, i'll cut a shock up and bolt it to the upper mount for even more of a stealth aspect.
