So twice as many things to go wrong with it.just means you have a dohc instaed of sohc. or instaed of 95 hp you have 110.....
lick your finger and then wipe it on the timing belt, then get in and turn the car over.....see if the wet spot moves
Okay, I had to use a wet towel but end result was the same. it started drizzeling here during the test (still is) and I am pretty shure it moved. wet spot was gone.
now I am going to get some sleep. Thank you for your help.
