Where to Shift RPM wise at the track w/ my mods? DarkFire , anyone??
xtweakerx
411
Jupiter,FL
Engine: 4.6L
GMS Driveshaft Loops
Hurst Line-Locks
5 Speed Transmission
Ford 4:10 Rear-end Gears
Brenspeed SCT2 Tune 93 Octane
Steeda Under Drive Pullies
C&L "Racer" Cold Air Intake
Steeda Upper & Lower Control Arms
M&H 275/50R17 Drag Radials
Pypes Off-Road H-Pipe
Flowmaster Axle-back Exhaust
I have been shifting at 6200. Lend me your thoughts.
Disappointed with my last time out at the track however it was god awful humidity 80% plus and temps 77&higher and also the first time back in the car racing in 6months at a new track plus i was testing out different tire pressures.
But i ran back to back 13.23 @ 104 w/ 1.90 and best of the night 1.87.
i plugged my values into Density Altitude calculator and it said 12.99 corrected whatever that means.. ; ) Hell im gonna go race this saturday should be great weather so ill try again, should i shift higher than 6200?
tweaker,
I'll power shift at 6200-6400.
I typically do 6200 on 1-2 and 2-3 and 6400 3-4.
I launch at 2500rpm on street tires and 5k on drag rubber
The 2 biggest things I had to work on to get sub 13sec times was traction at launch ( needed tires and front swaybar removed) and power shifting (took practice)
hey im going through the traps in 4th gear, i tried running 3rd gear out but i hit the rev limiter before i could make it , i tried it once because 4th gear is not long before the traps, but that was when i was shifting at 6200, so maybe shifting at 6400 will give me a bit more room to maybe make it in 3rd, i dont know its gonna be close though ; ) lol
wish me luck im going to go race saturday..
the height difference does make a difference i think its dropping the 4:10's down to 3.99-4.0's im not sure about all the way down to 3.90's that is a bit much.
From my experience I dont think I'll be able to run through the traps in 3rd because i tried it once already ; )
But i will say I don't believe i trap that high in 4th , but heck when i run this saturday ill take a look at my Tach to see what im trappin at, i got a GOOD Feeling about this Saturday as long as the weather holds up. :nice:
after my car got tuned, it never see's over 6200.
i believe its 6200 from 1st to 2nd, 6k 2nd to 3rd, 5,800 3rd to 4th, and converter locks up early.
my best mph is 108.54 with a auto, basic bolt ons and tune. on 20's as well.
i thought you 5 spd guys would be trapping higher?
I trap in 3rd gear at like 6500ish with stock 3.55s and stock tires... I have 4.10s waiting to go in, but I fear they may slow the car down at the track because I wil have to shift into 4th. It will be fun on the street though.
If you look at the hp/tq curves on a dyno graph, you will be surprised to see where the peaks are. In my opinion, shifting at 6000 or above is way too high for a basically stock engine. Personally, I set my shift light for 5500 to shift in the 5700-5800 range (taking into account reaction time for the shift light). I think there's a misconception about how high these engines need to be shifted for max ET.
What kind of times are you getting @5500?
I would think shifting at 1000rpm would yield max ET. :D
