Stang be tripping
Big Show 96
81
Louisiana
After I swapped the 96 engine for the 01, my car ran like a beast. I've been running it for a couple of months with no problems. I decided to change out the spark plugs for no good reason besides them having 82k on them. They where motorcrafts & replaced with motorcrafts. The car felt very sluggish for about two days & slowly started coming back around to almost perfect again. The problem is if I launch the car from a dead stop it will burn the tires bad & spin about 3ft when I shift to second. When I go from second to third the car kinda slugs down to about 5300rpms then picks back up strong. If I'm rolling in third gear and punch it, it runs perfect no issues. It's just the speed shift from second to third. The car was very consistant before the spark plug change. The car is completely tuned up. I unplugged the computer for 15 minutes to try & reset it but it runs the same. Also no check engine light.
1996 GT
BBK CAI
BBK 75mm TB
BBK O/R H-pipe
40 series flows
Steeda UDP
Ford racing Alumn drv shaft
Ford racing B springs
01 long block:hail2:
3:27 5spd
This morning it's doing the slug thing from first to second. It went from spinning about 3ft when shifting into second to falling on its face. Now the second to third shifts are acting correctly. When driving around and slowly pulling it thru the gears it runs 100%. Any suggestions????:shrug:
