Is this - push-rod - N.A. - street-able within 90% of the world's definition:
1. No bucking below 2000 RPM.
2. Good power BELOW 3000 RPM.
3. Does not rev past 3000 RPM on bway at reasonable speeds.
4. If you have a set up that revs lower: it does not BUCK AND has good power on the bway in top gear.
5. Cam lope not excessive. Like over .580 lift and you fail the definition most likely.
6. Does not require octane boost of any sort.
7. Does not require drag radials.
Did we miss anything? If you do not fall into this category and think your car is set up for street then you are prolly a quarter miler at heart. But if so what is your justification based on your set up? Thanks. :SNSign:
For the most part I guess you could say mine is similar to FFW True Street
