NEW GUY FROM HOUSTON
nemostang
WELL LET SEE WHAT I CAN LEARN HERE
I GOT A 13 SEC TRUCK NOW IM WONDERING IF I CAN LOWER MY CAR INTO THE 13 AT LEAST HIGH 13 LAST TIME I RAN IT I HIT A 15 FLAT BONE STOCK SOME HOW THAT ENGINE BLOWED UP WHEN MY CUZING HAD IT N NOW IT HAS A MARQUIS ENGINE BUT I GOT A 04 GT ENGINE WAITING TO GO IN
HERE ARE SOME PICS OF MY CAR THESE ARE OLD PICS
WELCOME TO STANGNET
What size wheels are those? If you ran those at the drag strip they are really going to slow you down.
Once you drop that '04 PI (power improved) engine in you should be able to click off high 13 second times just fine.
welcome .. what size of Houston u stay at? Im from houston and never seen u around , im sure i would of notice those 20" bullits !!!!
Houston is the biggest city in terms of area out of the top 5 most populated cities in America. I saw your thread a while back. I look forward to seeing your car out at the strip! We can lay the smack down on Maddox!:D
nemostang, welcome! NPI cars are slow as turds stock. It takes quite a bit to get them running strong. If you are looking for 13's, it takes about 800 bucks. pullies, H pipe, timing adjuster, pi intake, and a set of drag radials will get you high 13's at around 100mph if you can drive. Good luck. (btw, take the caps lock off)
Mark
HMD? :shrug:
Which area of Houston do you stay on? Who is installing the engine for you and are you doing any mods during the install (long tube headers most importantly)?
As for wanting to lay the smack down on me Mark--your skills at driving the vette are going to need to improve with your skating problem. NPI autos don't spin ;)
WELL GUYS I LIVE ON THE SE SIDE OF HOUSTON BY HOBBY AIRPORT
WELL RIGHT NOW IM LOOKING FOR A STALL N GEAR FOR MY TRUCK SO IT CAN HIT THE HIGH 12
AND THEN ILL INSTALL THE ENGINE ON MY MUSTANG WELL WHAT I WAS PLANNING ON DOING TO THE STANG WAS LT'S CAI PULLEY AND SOME SPRAY
do you have a stock differential as in its the same one the car came with from the factory?
i honestly no nothing about npi's though, i'd be willing to say 2.73's maybe :shrug: im sure im wrong though :shrug: someone else will chime. What you should go with though is anything between 3.73 and 4.10, maybe even 4.30 if you dont care about diminished mileage.
EDIT: O yeah, what year is your car??
quick question what does npi mean
for some reason i thought i had the 3.73
my car is a 97
yea if its a stock 97 read diff. then it won't have anything near 3.73's lol my stock 99 diff is 3.27's i think. Im sure a set of gears would really wake your car up :nice:
npi means "non-power improved or non-performance improved" which is the style of heads, cam and intake that came on 4.6L cars 98 and below. Beginning in 99, we received pi motors which have an upgraded head, intake and cam combination that boost power up to 260hp factory rated at the crank. A very common mod/swap in the mustang world is to take a set of pi heads/cams/intake and swap it over to an npi block, which results in different compressions and a substantial increase in power. Used pi heads, cams, and intakes are fairly cheap nowadays too. :D
dammm didnt know none of this wow that sucks i think ill just stick to modding my truck lol
