Electric Fan Wire??
asecretfile
228
Had a wire come loose on my electric fan (I think its a Flexalite, dunno it was on the car when I got it) but anyways its the green wire that comes off the little relay mounted by the radiator and goes into the engine bay. I read some sites that said wire it into the a/c trigger but I dont have a/c
wire it into ignition turn on wire?
thanks
If you connect the AC input to the ignition, the fan will run any time the key is on. Could someone have connected the AC input to a manual switch? That's what I would have done.
FWIW, if it is an AC input wire and the fan is thermostatically controlled, the fan should have still worked naturally on its own................
