I don't think this qualifies as 5.0 Tech, and pretty much NOBODY goes into the Sound/Shine forums, it seems, so ... here it goes.
Weird thing I encountered with my '84 since I threw in a little $5 Eclipse cd player (yep, five bucks - the CD part doesn't work): every other time I use the turn signal right or left, the radio shuts off for a second or two and then comes back on. Even stranger, when I have the headlights on, this problem never happens. It doesn't lose its memory, it just powers down for a second and then comes back on.
I've got a separate ground, power supply, and constant battery line for the radio independent of the other wiring because the jackhole prior owner somehow removed the stock main radio harness (but he left the speaker harness - go figure), and I've got the ground running straight to the frame, nice and clean to bare metal, so I know that's not it. I've also swapped out the turn signal flasher, thinking maybe it was part of the problem, but no change.
Is it possible that maybe my radio is just so sensitive that the slight voltage drop/spike caused by switching on the turn signal makes the radio shut off for a moment as some kind of protective thing? Is this something Eclipse decks are known to do, or what? Never had this problem with the crappy little Sony shaft-style radio I had in there before (a whole 20 watts of power, wooooo!), so unless this is exclusive to this particular brand/type of CD player, then ... I dunno.
Sooooo, anyone ever seen/heard of this kind of thing before? I'm planning on replacing the Eclipse with something else later on when I can afford it, but if this shut-off problem is due to a wiring issue, then I'd kinda like to iron that out, first. And, of course, I'd rather not "solve' the issue by just driving around with my headlights on all of the time just to avoid switching off the radio.
Ideas? Suggestions? Similar experiences?
